Jon (guest)
Guest
Posts: n/a
I am also having trouble getting one of the studs lined up in the appropriate hole. Any help would be greatly appreciated!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW E30 3 Series Motor Mount Replacement
Old 04-14-2011, 11:14 PM
Author of "101 Projects"
Wayne 962's Avatar
The only trick I can recommend is using a floor jack under the engine, or even supporting it with a larger transmission jack. That will give you some wiggle room, if I understand the question correctly.
- Wayne
sdp sdp is offline
Our engine mounts had complete sheared and the engine was shifted over against the frame.
We used a crowbar with a block of wood in the engine compartment while another fitted the engine mount along with a floor jack lifting the engine.
Old 04-16-2011, 07:57 PM
