Alex (guest)
Guest
Posts: n/a
Hi,
I have a 328i and was not able to loosen the fan clutch nutyes, I know it has left handed thread. I used all the recommended tricks except for the bmw fan tool, which I couldn't find anywhere. So, it was actually quicker and easier to remove the radiatorwithout removing the fan or the plastic shroud to get the clearance I needed for a ratchet, and my hand.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Thermostat Replacement
Old 04-17-2011, 06:17 PM
Author of "101 Projects"
Wayne 962's Avatar
If you simply put "fan removal tool" into our search engine, it will come right up. Here's a direct link: http://www.pelicanparts.com/bmw/catalog/shopcart/BE36/POR_BE36_TOLtol_pg9.htm#item58
- Wayne
