			 Guest
					Posts: n/a
			How about changing the clock light on a '96 318i convertible?  It is on the lower console panel along with the outside air temp gauge.  If I can get the panel off...
				__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing BMW Gauge Cluster Light Bulbs  |
			 Author of "101 Projects"
			The clock is located inside the multi-function unit.  You can access the bulbs by removing the storage container underneath (it should just pull out with some coaxing), and then you can pull out the unit above and replace the bulbs, just like in the cluster.
			- Wayne
	Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports  |
			I have a '95 318is, and I did it a little different, I had to slip a thin piece of metal in at the top and bottom of the console and slide it along to release the tabs that hold in the console.  It took some coaxing to get it out.  I helped push it out thru the access hole that is directly underneath the console (on the roof of the storage container).
