Rodman (guest)
Guest
Posts: n/a
Hi I have a 1990 325i BMW. I have replaced the alt and battery and it still won't hold a charge. I looked on some forms and they said the battery light is a fuseable link and if it was out it would cause it not to charge. I checked the bulb and it's good but the car still won't hold a charge. If I could get so help it would be greatly appreciated.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Troubleshooting Electrical Problems on Your BMW
Old 04-18-2011, 03:07 AM
Author of "101 Projects"
Wayne 962's Avatar
I don't think that battery is as you describe. I think on older cars, some were setup similar to that, but not as far as I know on your car. More likely you have a poor ground between the battery and the alternator. Check the resistance using an ohm-meter between the battery negative and the housing of the alternator - should be near zero. If not, you may have a missing or disconnected engine / transmission ground strap.
- Wayne
