Need help removing the instrument cluster
I'm trying to pull the instrument cluster on an '88 325is. I removed the two little screws. I can pull the plastic trim piece all the way out at the top, but the bottom is held in place. The plastic seems ready to snap. Is there a trick to get the bottom free?
I haven't done this in a while, but there are screws at the bottom as well.
Thanks. It was finding the two knurled knobs that help hold the flat trim plate under the cluster in place. Found the screws and got the cluster out.
| All times are GMT -8. The time now is 02:58 PM. |
