E30 1986 325e cut gas this morning
ok so this morning i was driving fine until i started to cut off and i was able to do only 20mph then it shut off i pull over and started up and it was fine so i keep driving for about 10miles and it did it ones more time, this time it would not turn on. motor crank but wont turn on. I notice my fuel pump would not turn on at all until i jump it were the relay goes. I got the fuel pump running but with jumping it with the wires but still wont turn on. i know it haves gas but my sender unit is not working right . would my sender unit have to do with the fuel pump not working. please help
Old 07-14-2011, 04:49 PM
fuel pump relay, fuel pump, pulse sensor, and in your case, e30 ignition switch failure is common.
just places to start looking.
i used to have to pull the key back a little when the starter engaged to get ignition on my 88.
but it was a cabro and was exposed to florida weather.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 07-14-2011, 11:24 PM
is it possible if the pulse sensor is not working , my fuel pump cuts power?????
Old 07-15-2011, 02:37 AM
OK so i check everything and noting. its like the their is no power to the fuel pump like a shut off switch . the fuel pump works only when i jump it from where the relay goes. my relays are good my ignition switch is good and i change the pulse sensor . i am stump any body know what could be wrong
Old 07-15-2011, 03:35 PM
yes, the ecm can't confirm that the engine is turning (input from pulse sensor)it will de-energize the fuel pump relay after a few seconds. It is a safety thing, if you had an accident or a broken fuel line you wouldn't wantthe fuel pump to continue to pump gas all over the place.
Old 07-15-2011, 03:42 PM
what about the external fuel pump!! if it is un plug would that cut the gas and to tell you the true when i connect the fuel pump direct from the relay spot i smell a little gas running but don't know from the driver seat if it is coming from the inside of the car or the engine compartment
Old 07-15-2011, 04:15 PM
