-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   1984 325 e Need to replace odometer (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/634541-1984-325-e-need-replace-odometer.html)
Henry2JT 10-13-2011 01:15 PM
How do I do it?
Rrrockhound 10-13-2011 05:19 PM
Why do you need to replace it? Is it not working? Because it can be fixed.
Jared at Pelican Parts 10-17-2011 08:52 AM
The odometer is usually replaced as part of the whole instument cluster. YOu dont usually see the odometer separate.
The odometers can be fixed.. Try North Hollywood Speedometer or Palo Alto Speedometer.
Rrrockhound 10-17-2011 05:07 PM
The odometer is an easy DIY fix if the problem is just stripped gears.
odometergears.com has parts, instructions, and good close-up pictures.
