E36 DME Question
I am having DME issues and have a 1994 318I with the 261-203-357 DME, can I switch it with a 261-203-282 DME? if I find another 261-203-357 DME will I need to switch my computer chip, or can I plug it in and expect it to run?
PS: I would appreciate a response from anyone what can answer the question asap!!!! Thanks |
DME e36 July 1994 318i Bosch OBD I / DME
Were you able to work out an answer to your chip question?
I have a 318i e36 July 1994 Bosch OBD I / DME that does not activate when procedure is followed. Car is running fine but cannot activate the DME to see the fault codes and apparently it might not be working. I had no replies to my post either so I was guessing to try replacing the 'chip' without having a clue what I am doing. Any ideas...anyone? Cheers |
| All times are GMT -8. The time now is 09:06 AM. |
