-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   acceleration problems (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/639256-acceleration-problems.html)
aussey123 11-10-2011 08:22 PM
I have 1995 bmw 325is recently it has been jerking a litlle when pressing on the gas pedal from stand still, now sometimes when on the highway when wanting to increase speed. I have not had it too much when on a steady speed. I am not sure whats going on . have had fuel filter change and air so far. doe not happen often, help:confused:
Manolito 11-10-2011 09:26 PM
Start with a careful review of all the ductwork from the mass airflow sensor to the throttle body. You are looking for cracked plastic or rubber that lets unmeasured air leak in.
If the intake side is tight, check the exhaust side for leaks that could be tripping up the oxygen sensors.
Shagg 11-11-2011 02:15 PM
I have a similar problem... I have an E36 328i Automatic.
I have replaced the coils, plugs for a service… all worked fine apart from an error code faulting O2 sensors, as it had a rough idle so we replaced them, car went ok but still had a slightly rough idle, after a few days the car started to loose performance, now the car has virtually no power once it has warmed up (about 5 min) and is running rich and occasionally spits back through the manifold then it came up with an AMS error, we replaced that and reset the error code, no change! It came up with another AMS error so we put another new on in (OEM), still no change. Runs a little better in sport mode. We have checked for leaks in the inlet side, boot is like new and we have no exhaust leaks.
We have now put back the old O2 sensors… no change… Tried the all 3 AMS sensors (including the original) still no luck.
Could it be the ECU????? (There is no water damage around the ECU)
If so can we just replace the chip?
