Mike (guest)
Guest
Posts: n/a
Okay, figured things out. But still have to replace the valve cover.
I failed to remove the additional 4 bolts near the spark plug ports.
Everything is disassembled, cleaned and ready to install.
Car will be out of commission for a few days, but its driver my daughter is in Hawaii for a couple of weeks. I should have it buttoned up within the next couple of days.
Just a bit more expensive than I initially thought.
Live and learn.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Valve Cover Replacement
Old 12-18-2011, 02:51 PM
Author of "101 Projects"
Wayne 962's Avatar
Oops. Those are indeed pretty small. No worries, we all make mistakes like these. You can find a used one probably on eBay - we do sell these on the site, if you contact sales, they will check on exactly what you need. If it's a very small crack too, you can possibly JB Weld it. You want to make sure it doesn't leak oil or crankcase vacuum.
- Wayne
