A**** The Best possible support provided, with this a beginner can act a pro!!!!! People should donate to whom provided all these detailed pictures and text I would like to !!
Quick suggestion,, To open the top torx bolts on the gearbox, remove a few pipes from the engine compartment near the slave cylinder and you will find you can fit your arm hand - into towards the bolts, easy = use a small spanner a torx or an star shape 10 - small rachet. Hope this helps ! Any questions about BMW or MERCEDES - German cars welcome ?? __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Clutch Replacement |
Thanks for the kudos and the tip!
- Wayne |
thanks for the tips..:D
Also consider that the engine itself can be tilted a few degrees to allow better access to the top tranny bolts.
| All times are GMT -8. The time now is 04:04 AM. |
