Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
stuck fuel pump
1987 325i conv. manufactured in nov.
can't get fuel pump out of gas tank.
elect, and fuel disconnected.
hanger/pump assembly is disconnected from tank, but unable to maneuver it out.
Old 06-01-2012, 01:37 PM
undo thoses 4 8mm nuts and remove the fuel level sending unit, then you can rotate the main housiing and remove the pump, there is a flat section on the base, so angle it over when almost removed.
Old 06-03-2012, 11:44 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
