LinkBack Thread Tools Rating: Thread Rating: 1 votes, 2.00 average.
1996 318ti door locks and dome light
Trying to determine cause of following lock and dome light problem.
1. Dome light switch in middle position, but light stays on, does not fade out.
2. Power door lock button on center console does not work.
3. Car will central lock/unlock by turning key in driver's door lock only.
4. Car will not central lock from trunk or passenger door.
I looked at the hatch wiring and found no bare wires. Hatch light switch works properly but probably will replace. Would like to isolate problem.
Any help is greatly appreciated.
Old 11-09-2009, 01:40 PM
I have the exact same problem: anybody has hints?
This is the rear door switches for the dome light, located on the door jams. It's working properly but jiggling the door open, keeping the switch pressed, will cause the dome light to turn on. Strangely, if I lock the car with that door open (this is the solution for the moment), car will lock properly, even thou the switch is not being pressed.
Thanks everybody
1982 911 SC Targa (USA)
Old 10-29-2012, 02:46 AM
Looks like it's the door harness' fault. Anybody has a clue on what to check? Which specific wires maybe? Thanks a lot
Old 11-07-2012, 03:33 PM
