BMW Roundel 95 325ic driver window D.O.A.
My window is stuck in the up position... doesn't even bump when closing the door for clearance. all other windows work, i hear a click when i activate the switch... no motion... i took the panel off. No click when i pull the power plug. duh. i hear the click when i disconnect the lower plug (whatever that does) So, I'm guessing the motor is shot... can i replace the motor without pulling the lever assembly for the window? also, how do you remove the speaker wires plugs!!!
Old 02-09-2013, 10:58 AM
Tags
speaker removal , window , window motor
