ignition issues
My ignition is acting up, when i pull the key out the odometer stays on along with the obc and the radio and the battery drains after a two days of not driving it
another problem the car takes about 2 to 5 sec to fire ,, and thats after replacing the fuel pump, regulator, filter and i dont smell gas whatsoever and the spark plugs, boots, and used coil packs, camshaft sensor the only thing i can think that can make the car start after 5 sec is the injectors, i have replaced the o-rings and gaskets but im thinking about taking them off and getting them cleaned any input is greatly appreciated |
I wonder if you have a temperature sensor that is telling the computer that the car is at full operating temperature when it is cold? Does this happen on warm restarts or just on cold start?
cold starts usually or after 30 min being turned off
| All times are GMT -8. The time now is 07:19 PM. |
