sickmike (guest)
Guest
Posts: n/a
Hi, I am having a problem with my e30 and i think it might be the CPS.. It wants to start sometimes and when it does it holds idle for 1 second.. I can spray starter fluid and it will go.. so I'm kinda confused. Could this be a CPS issue?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Crankshaft Position Sensor Replacement
Old 05-03-2013, 03:14 AM
Nick at Pelican Parts's Avatar
If it runs when you add fuel, then engine has spark. This would tell me the crankshaft sensor is fine. The I would check if you are missing fuel pressure or fuel injector pulse.
- Nick
