-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Should I remove my O2 sensor with a hot exhaust? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/752735-should-i-remove-my-o2-sensor-hot-exhaust.html)
kbana 05-28-2013 10:43 AM
Hi guys, I just replaced my sensor & the old one unscrewed like a dream. Disclaimer; this worked for me, I take no responsibility for the advice. I drove the car for an hour & ensured that the exhaust was very hot. I prepared with eye protection & thick gloves, I then used a shifter to remove the old sensor, a light tug is all it took. Mind you I did try removing the sensor cold, but it wouldn't budge. So the trick which worked for me is to replace the sensor when exhaust is very hot, but protect yourself & be careful. Best of luck in your DIY
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your 3-Series E30 Oxygen (Lambda) Sensor
Nick at Pelican Parts 05-28-2013 10:43 AM
Yes heat does make the metal softer and easier to remove. Avoid using rust penetrate sprays because they have silicone in them and this will damage the sensor element.
- Nick
