Use a torch to heat the bung the o2 sensor threads into if you are having difficulty removing it....I.E. it is seized.....don't be a jerk & put visegrips on it...use a 22mm wrench or the appropriate tool if you want to avoid a mechanic....anyways don't drive a bmw if you cannot afford to maintain it in the 1st place....buy a kia
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your 3-Series E30 Oxygen (Lambda) Sensor |
Thanks for the tip
- Nick |
| All times are GMT -8. The time now is 03:02 PM. |
