-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Whats the difficulty rating and procedure for a DIY job of replacing the TPS? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/760974-whats-difficulty-rating-procedure-diy-job-replacing-tps.html)
Larry (guest) 07-15-2013 06:40 AM
Hi. I need to replace the throttle position sensor on my BMW E36 320i M50 non vanos DME 3.1 Whats the difficulty rating and procedure for a DIY job? I already have the replacement sensor
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-15-2013 06:40 AM
The TPS is bolted directly to the throttle bore. You may have to remove the whole throttle bore to make it easier and if you do you should replace the gasket.
- Nick
