spug (guest)
Guest
Posts: n/a
Have a 330xi 2003 was thinking of flushing and changing the transmission fluid/filter,has 150000 miles and when it's cold it doesn't connect into drive from reverse right away,I read somewhere it could be a solenoid valve,is that true and could I do it myself?
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-15-2013, 07:29 AM
Nick at Pelican Parts's Avatar
There are several solenoid valves in the valve body and you are going to have to be able to determine which one is the reverse solenoid of the group
- Nick
