-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   o I have a bad thermostat or not enough coolant? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/761026-o-i-have-bad-thermostat-not-enough-coolant.html)
Fitz (guest) 07-15-2013 07:01 AM
Wayne, I replaced all components to the cooling system on my M3 E36. Looks like I put in all correct. Sucked in 1gallon of BMW antifreeze mixed with 1 gallon of distilled water. Is that enough or do I need to add more? The engine operates at normal temperature but will not warm up in the interior the air stays luke warm, I turned on the AC and it gets cold quick. Do I have a bad thermostat or not enough coolant?
http://www.pelicanparts.com/more_inf...04145-9848.jpg
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-15-2013 07:01 AM
Your thermostat may be stuck open or the duovalve/heater valve may be stuck closed. What is the coolant level in the reserve tank?
- Nick
