My drivers side sedan window came off track and I prolly bent one of the articulating arms pulling it up into the closed position.
Bummer. Four rivets had to be drilled / ground out to remove the whole regulator to straighten the arm out. It can be done. Upside is that it all can be easily lubed when removed. I used nuts, bolts, lock washers and loctite blue to re-install. The clips that hold the balls in the nylon sockets are easy to install with window almost all the way down by using a long needle nose pliers. This was 4 hour exercise:/ but very doable and in my case, no new parts needed: __________________ This post was auto-generated based upon a question asked on our tech article page here: |
Good work
- Nick |
| All times are GMT -8. The time now is 02:54 PM. |
