Follow up to Nick; I fixed a leaky camshaft seal and o-ring as well as replaced inner/outer control arm ball joints and bushings totally unrelated to my oil leak but it had to be done. I don't get an RPM dip in reverse anymore and the engine vibration is not as noticeable. Can't say I can explain it. Haven't driven the car enough to see if the symptoms return.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
A change in vibration may have affected the knock sensor changing the ignition curve
- Nick |
| All times are GMT -8. The time now is 07:37 AM. |
