AMX (guest)
Guest
Posts: n/a
Can someone help, please? I swapped a motors, dropped in a 325es into my 325i convertible. A few adjustments were made for the 325es to work. It turns over and stays on for about 1-2 seconds and then shuts off. It won't stay idle. I changed the idle control module and it's doing the same thing. Does anyone know what other adjustments need to be for it to idle right? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-11-2013, 10:29 PM
If you step on the gas can you keep it running? What were the few adjustments? The ES and the I are different motors not to mention different fuel injection systems. The crank sensors and cam sensors are in different spots. Also, doesn't the old ES motor have a two wire idle air motor and the I have a 3 wire idle air motor. You are going to need to get a repair manual for the ES and the I models and match the I components to the ES, or you can get an I computer and harness and change that.
- Kerry
