joe (guest)
Guest
Posts: n/a
my 318i e30 spark plugs stay wet dont wana start
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-11-2013, 09:42 PM
Your engine is flooding during a crank. Clean all the plugs and try to start it while flooring the gas pedal. It may start but will probably run poor. Your valve timing could be off, your pressure regulator may have ruptured allowing raw gas to be sucked into the intake through the vacuum line (disconnect the line and look for raw fuel) or the fuel injection system is opening the injectors too long, maybe from a bad coolant temperature sensor (CTS) signal. Make sure the CTS connection is clean.
- Kerry
