 Just did the E30 rear end swap into my 95' E36 318ti and I'm wondering how warm a LSD diff should get?  After 30 minutes of spirited driving I shot the cast iron part of the housing with the I/R gun and the temps are about 230 degrees. The air temp was also only about 60 degrees so I'm worried on a 90 degree day its gonna get to warm.  Unfortunately I didn't check the old open rear end before I removed it so I don't what that use to run.  Using Redline synthetic oil in both.  What kind of temps should these be running at? __________________ This post was auto-generated based upon a question asked on our tech article page here: |
 I can't give you specific temps since there are too many variables. You need a limited slip friction modifier additive for LSD and there is a chance that the clutches are slightly worn and allowing the unit to get hot from the slipping.  - Kerry |
| All times are GMT -8. The time now is 01:25 AM. |
