LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
My BMW 320i 2002 is showing an EML sign which i do not understand what it means.After showing the sign it can only do 80km/hr and wont go any further like its powerless even if the accelerator pedal is pressed fully. computer diagnosis reads engine throttle output shuts off after diagn.error, all the sensors are said to be ok and i rilly do not know wat it is then.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
This means you have a problem with the electronic throttle. Have the code cleared and see if everything goes back to normal. You can try disconnecting the battery and see if that resets it. You are going to lose your radio station presets. Also when reconnecting the battery turn the ignition on for at least 90 seconds to reset the throttle adaptation.
- Kerry |
