chris (guest)
Guest
Posts: n/a
Followup from the Pelican Staff: Does coolant come out of the bleed screw when you open it. Be careful the coolant will be hot. Did you change the thermostat? If that is stuck closed the coolant will not circulate. - Kerry at Pelican Parts
Well i let the car run the other day thinking i missed an air pocket, when i open the bleed sscrew, it does come out when i have the coolant topped off, but it only comes out a bit, it does not bubble , i am going to take the thermostat out tomorrow and test it
thanks
christian
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-15-2013, 06:59 PM
Please let us know what you find with the thermostat
- Kerry
