berbes (guest)
Guest
Posts: n/a
my problem is, alot of heat coming out of the footwell areas when i don't want it to. no leaks anywhere. can this be caused by a sticky heat valve too?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-15-2013, 07:50 PM
No leaks from where? You may have a bad footwell actuator in you HVAC box. You might be able to see it if you remove some lower panels under the dash board
- Kerry
