2002 330 After seeing signs ofleaking coolant, the local BMW shop former dealer told me the water pump was leaking. They replaced the waterpump and thermostat. Now I have no heat for about 3-5 miles depending on outside temp until temp guage reaches normal, at which time the low coolant light comes on and the heat finally starts to work. Previously I had heat in about 1 mile. Did they screw something up? System pressure tests good 3 hr. Coolant level is good at filler cap.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Try opening the bleed screw while the car is warming up. You may have an air pocket. Also look at the flow in the coolant expansion tank.
- Kerry |
| All times are GMT -8. The time now is 05:44 PM. |
