-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   I have no heat for about 3-5 miles depending on outside temp until temp guage reaches normal? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/766266-i-have-no-heat-about-3-5-miles-depending-outside-temp-until-temp-guage-reaches-normal.html)
Yakima Jim (guest) 08-15-2013 08:07 PM
2002 330 After seeing signs ofleaking coolant, the local BMW shop former dealer told me the water pump was leaking. They replaced the waterpump and thermostat. Now I have no heat for about 3-5 miles depending on outside temp until temp guage reaches normal, at which time the low coolant light comes on and the heat finally starts to work. Previously I had heat in about 1 mile. Did they screw something up? System pressure tests good 3 hr. Coolant level is good at filler cap.
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 08-15-2013 08:07 PM
Try opening the bleed screw while the car is warming up. You may have an air pocket. Also look at the flow in the coolant expansion tank.
- Kerry
