-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   My reverse lights do not work at all? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/766310-my-reverse-lights-do-not-work-all.html)
SAL (guest) 08-16-2013 07:46 AM
P.S.S. One other thing... My reverse lights do not work at all. The day my problem began, I had swapped out my tail lights for some clear/red ones. After doing some search, it may seem my Reverse Light Switch located on trasmission might be out too. Could that cause something to bad?? PLEASE HELP!!!
P.S. None of my dash lights are on or anything has come on prior to my problem...
This is additional info regarding my post about my Automatic 92 E36 325i :
I have a 92 E36 325i Automatic. I purchased this car a little over a year ago. A few days ago, with out any warning, I noticed it wasn't shifting over to second gear. There is a loss in power and a delay in accelaration when I step on the gas Ex. From a complete stop or pulling out of my driveway At most, I can get it up to 50-55mph and the RPM guage is displaying 3,000. Will a transmission oil change help or am I looking into Transmission work???
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 08-16-2013 07:46 AM
Your gear selector switch, which may control your reverse lights, also indicates the gear position to your transmission control unit. If the gear selector switch is not working that may be the cause of your transmission shifting problem. Maybe when you swapped the tail-light lens you blew the fuse for the reverse lights and now your gear selector switch is not working. Which questions did you want answered?
- Kerry
