-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   when I press the accelerator to go faster is starts to jerk? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/768007-when-i-press-accelerator-go-faster-starts-jerk.html)
blane031 (guest) 08-26-2013 06:03 PM
Hi there. Im from south africa and I have a 89 e30 318i. M40 motor
I have just rebuilt the eNtire motor, rebore 20 tho. I had a problem with a rough idle and changed the idle valve, seem to sort the problem out but wen I drive car runs smooth and wen I press the accelerator to go faster is starts tp jerk and once I leave the pedal n press again it accelerates proplly. What can b the cause of this?
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 08-26-2013 06:03 PM
It could be the valve timing is not correct, or the throttle position switch/sensor is faulty or you have a worn airflow meter
- Kerry
