-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Could this be the ICV and if so where is it located? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/768014-could-icv-if-so-where-located.html)
Big Amp (guest) 08-26-2013 06:12 PM
My 03' BMW 325i will not idle. it's not surging but starts and shuts off if I don't press the accelerator. Scanned it and it shows a mis-fire code. Could this be the ICV and if so where is it located? Need help!!!!!!!
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 08-26-2013 06:12 PM
Find the source of the misfire first as that can damage your engine. Fix that and you will probably take care of your other problems. Most BMWs miss because they are running too lean but without much to go on I'm just guessing. What is an ICV? Intake Control Valve?
- Kerry
