ratfink77 (guest)
Guest
Posts: n/a
Detailed diagrams of every BMW you can imagine are on realoem.com. If you can't find pictures, check it out.
If your injectors are stuck in the intake, spray some penetrating oil around the base of the injectors, then wiggle the whole rail and pull. Mine still wouldn't loosen, so I rigged a couple of pry bars with valve cover removed to pry up on the front end of the rail and it popped loose.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-26-2013, 06:27 PM
Thanks for the tips for our readers
- Kerry
