e30 hobby car (guest)
Guest
Posts: n/a
I have followed this exactly, i have used as much force as I can muster and I can not get the injectors and fuel rail out! those injectors are stuck in there!!!
any suggestions?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-27-2013, 05:53 PM
Try spraying the base of the injector with carb spray. It will libricate the o-rings until the spray evaporates. You can lever up on the rail a little, it is made of metal. Be sure to have spare replacement 0-rings around it case some of them break.
- Kerry
