Superbmw 88 (guest)
Guest
Posts: n/a
Another way to help to remove the water pump is to remove your Radiator and Condenser this will allow you to put a small slide hammer on the water pump and give few strong slides and it will slowly move out. It take a while to make it work, but as I was helping a friend of mine to remove his same problem as my, but it took two guys 3 hours to get everything removed and took 20 Minutes with slide hammer of constant pounding finally it give, so this can be a good idea for all E36 4 Cylinder Cars.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-27-2013, 07:17 PM
Thanks for the advice for our readers
- Kerry
