i have a 1992 bmw 325i,how many 02 sensor does t have ,coz ive been having eratic idling cold start and ive already replaced icv,map but still having the same problem..need sos advice pls
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
There should only be one before the cat. Cold starting problems could be related to a vacuum leak, inspect the engine for a cracked intake boot, vacuum line or leaking gasket. You can also check the crankcase vacuum, this will help you diagnose the crankcase breather valve.
- Nick |
| All times are GMT -8. The time now is 03:39 PM. |
