-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   a few questions? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/774673-few-questions.html)
M3 (guest) 10-02-2013 09:14 PM
Hello ! I'm working on a 1991 M3, a few questions..
1 If I replace my front w Bilsteins Sport Package, would lowering this car seem wrong being that its an M3 ?
2 If changing the rear Coils and shocks w Bilsteins Sport Pack, would I have to toy w Camber or anything else or is it a direct replace and then complete ?
3I see on the Front shock under the bearing some old Bushing, w replacing w Bilstein shocks, do I need this Bushing ?Not the one with a bearing on it
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 10-02-2013 09:14 PM
You can go lower than a stock M3.
Lowering the car will give you more camber and you should get a wheel alignment.
If you see a worn bushing you should replace it
- Kerry
