Travis (guest)
Guest
Posts: n/a
I had to adjust my throttle cable in doing this procedure...any idea as to where it's supposed to be set to? or how to adjust it back to an OEM setting? I have a 1991 318i with an M42, thank you...
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-10-2013, 12:00 PM
There is no OEM specific setting. Loosen the cable until you can move the pedal and the throttle will not move. Tighten the cable until the there is a small amount of pedal movement before the throttle move. Any tighter and the cable will eventually break.
- Kerry
