-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   although I had got it to start when I Jump the starter, would not start with the key (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/776598-although-i-had-got-start-when-i-jump-starter-would-not-start-key.html)
Ross (guest) 10-15-2013 05:25 AM
Hi I'm having some trouble starting my Car. It is a 2002 BMW 325 CI. The car won't crank nor start soon after I replaced the clutch and the intake cover gasket. although I had got it to start when I Jump the starter, would not start with the key, any advise will greatly be appreciated
Thanks so much!
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 10-15-2013 05:25 AM
Don't know how your starting problem post ended up in the E brake adjustment section but it sounds like you left a connection unplugged. Put a test light on the starter smal wire and see if it has power when you put the key in the crank position, Check all the electrical connections you unplugged to do the job. Possible a wire broke inside the harness when you moved it, old harness get brittle over time
- Kerry
