bmwm1 (guest)
Guest
Posts: n/a
I found a motorsport emblem that is the exact size as the one on the steering wheel for the 335. I now need to figure out how to remove the existing emblem without damaging the horn pad. any help?
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-15-2013, 05:38 AM
If your steering pad has an airbag it I cannot recmmend that you take it apart. If you do not have an airbag try removing the cover and replac0ing the emblem and try not to use sharp tools or you will cut the cover
- Kerry
