1998 M Roadster. Power Convertible top won't work. No voltage / power to motor. Micro switches seem to be ok, power top switch seems ok. Could this problem be from a bad relay?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Probably a bad control unit if the input switch is working and all the micro switches are okay. What happens when you manually open the top and try to close it with the switch?
- Kerry |
| All times are GMT -8. The time now is 05:46 PM. |
