Mike4198 (guest)
Guest
Posts: n/a
Hi, could mine be a sensor issue too? i have a 2006 325i bmw and i noticed now in the winter time when its cold out that after a while driving my fan under the engine kicks on real high and stays that way until i turn car off. could that be a sensor issue too? i notice it also seems to effect my heat temp working in my car too, to try to stay warm in this winter weather. You think coolant issue too?
thank you in advance
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-13-2013, 05:07 AM
It could be air in the system, bad water pump/low coolant flow or bad coolant sensor.
- Kerry
