OK, found the heater valve right where you said it was . Never doubted you. Cannot get it off the mount. Rubber round bushing on the top slides off easy. bottom rubber mount does not. Should i be removing the metal bracket it is attached to ?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Yes remove the metal bracket the rubber is there to insulate it from vibration
- Kerry |
| All times are GMT -8. The time now is 03:12 PM. |
