If the crank sensor is damaged, will it not allow the the automatic transmission to shift gears? E30 325i. Please help
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
No the crank sensor is for the DME not the EGS. This is probably a mechanical auto trans. Check your fluid level in your trans.
- Kerry |
| All times are GMT -8. The time now is 04:02 PM. |
