-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Error code says: Ratio monitoring gear shift 2-3? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/783659-error-code-says-ratio-monitoring-gear-shift-2-3-a.html)
Steve (guest) 11-24-2013 03:32 PM
Adding to the previous post:
What does this mean?
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 11-24-2013 03:32 PM
The EGS control unit looks at the input shaft speed sensor and the output shaft speed sensor to tell if the transmission clutches are slipping. This means the 2-3 clutch is slipping. This could be due to a sticking shift/pressure control solenoid or sticking piston is valve body. A fluid exhange may cure this.
- Kerry
