-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   oils and filters (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/80566-oils-filters.html)
97XRAY 09-13-2002 10:02 AM
oils and filters
Now that the 48,000 mile mark has arrived, the dealer will no longer provide standard service free of charge.
I'm wondering what OEM filters are available, and I'd like to know opinions on oil types vs. performance and engine wear for the 323 series.
Thanks!
Dave at Pelican Parts 09-13-2002 02:06 PM
I don't really know about the filters for sure, but I would definitely stay away from Fram. They seem to be really cheap and somewhat flimsy in construction... I've been using Purolator or Wix for my "other car", and OEM (Mann, Mahle, Knecht, Bosch) for my 914.
As for oil, I use "dino" oil in my older motors, mostly because they tend to leak and synthetic will generally leak faster than dino oil. (I use Kendall dino oil in my 914 and my "other car".) But for a newer motor like in the E36 cars, I would strongly consider a synthetic or "hydro-cracked" oil. I would not use the full extended oil change interval, though that may be because I'm paranoid due to my 914's air-cooled engine.
Mobil-1 is a good hydro-cracked oil, though I've heard that there is a Valvoline fomulation that also uses hydro-craked oils (I think they're called Group III stock?) that is less expensive and seems to be as good. Some claim it's better, as M1 has reduced their additive package in the past couple of years.
Full synthetics tend to be very pricey--Torco, Redline, etc. But if you can stomach the expense, they are a very good way to go.
--DD
nydog 12-02-2002 09:32 PM
check ebay. i bought OEM quality oil filters (Mann i believe) from a guy on the there some time ago . he usually sells them in batches of 5 and includes all the o-rings for about $20 shipped
umnitza 12-03-2002 03:02 PM
I bought from the same guy - those filters are fine:)
Racko 12-04-2002 08:15 AM
Mann or Mahle filter & Mobil1 0W40 or 15W50.
umnitza 12-05-2002 02:39 PM
1 Attachment(s)
mahle is
nydog 12-05-2002 06:14 PM
actually they were Mahle
eren 12-08-2002 06:41 PM
Mann and Mahle are both good. I purchase my filters at www.ips-parts.com or www.performancemotorcars.com. There are hundreds of online seller there. You can find these filter everywhere online.
97XRAY 12-09-2002 06:37 AM
What is that thing with strips running up and down it... the filters I have for the porsche are what I think of as regular / smooth and cylindrical on the outside. I'm confused about whether this is a cooling device for the outside of the filter, or if it's the actual filter.
http://forums.pelicanparts.com/uploads/weird look.jpg
Here's a blow up of the THINGY in question:
http://forums.pelicanparts.com/uploa...0249919MAN.jpg
Thanks for helping the ignoramus!
Racko 12-09-2002 06:47 AM
This is only filter element, metal casing comes with car and it is not replaced with filter like on some other cars. I hope I answered your question.
97XRAY 12-09-2002 06:49 AM
REALLY!!!
Who Knew?!
That's interesting, thanks.
Racko 12-09-2002 06:57 AM
Yes, on my 96 328i I have 36 mm socket, remove round black cylinder and replace filter element & O-ring and re-install cylinder. You realy shoud buy Bentleys manual it's very helpfull.
Racko 12-09-2002 07:01 AM
See www.logun.org there is a lot of DIY's with pics.
