-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Question on BMW 3-Series E36 O2_Sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/807255-question-bmw-3-series-e36-o2_sensor.html)
markovnik222 (guest) 04-20-2014 06:49 AM
hi. i have a problem with my MAF sensor. when MAF sensor is connected i start a car he's cut off. when i disconnect a plug from MAF sensor car starts good. i had changed to a new MAF sensor, still the same. i tried to blow into MAF sensor when he's connected engine starts cut off. i think maybe when i replaced a new MAF sensor i need reset ecu. any ideas what i need tyo do? thanks
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 04-20-2014 06:49 AM
Have you checked for fault codes? I would assume the MAF is not your issue. You may have a vacuum leak or fuel delivery issue.
- Nick
