-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Question on BMW 3-Series E36 O2_Sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/834834-question-bmw-3-series-e36-o2_sensor.html)
Baba (guest) 10-20-2014 07:31 AM
Can a faulty air sensor valve in a BMW 3 series cause a car to go to a limp mode?.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-20-2014 07:31 AM
Trans limp? Not likely. First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
